pgrbff
I want to trim the ends of some maple-type logs before painting with end seal, at the moment they have very rough ends.
What handsaw will give me a clean cut?
I have tried with western and Japanese saws, the coarsest I have, it's just too wet.I'm no sawing expert so this is just my thoughts on the subject.
A bow saw is going to wander as it is just designed to cut wide logs quickly. You are also likely to have a lot of saw marks as they are large toothed and it's quite likely the teeth are not perfectly aligned.
A big panel saw with a fine tooth is likely to be your best bet, something like this maybe Magnusson 14tpi Wood Floorboard Saw 20" (500mm) - Screwfix
It'll take longer to get through the log with the finer tooth but you should get a better finish. You'd just have to saw slowly and try and remain as straight as possible
I think the only reasonably priced option might be a raker tooth Fiskars bowsaw.I don't think any of the pruning saws or bow saws will give a smooth finish. Overall a bow saw fitted with a raker tooth blade is your best option. Dry wood needs a peg tooth blade. You might also consider a ratchet type lopers which will handle anything up to 40 cms diameter and will leave a smoother finish than a saw.
Loppers for 40cm diameter?? You’ve got bigger muscles th an me!I don't think any of the pruning saws or bow saws will give a smooth finish. Overall a bow saw fitted with a raker tooth blade is your best option. Dry wood needs a peg tooth blade. You might also consider a ratchet type lopers which will handle anything up to 40 cms diameter and will leave a smoother finish than a saw.
Do you mean 40mm (4cm)? The OP is talking about 40cm logs. I've never seen lopers that can cut through a 40cm log!ratchet type lopers which will handle anything up to 40 cms
Sorry , a bit early for me. Yes, I read it as 40 mm not cms. Actually a ratchet loper will do cuts up to 40 mm. The key is the ratchet mechanism which allows you to take two or three bites .However for 40 cms I think you will need a chainsaw.Do you mean 40mm (4cm)? The OP is talking about 40cm logs. I've never seen lopers that can cut through a 40cm log!
Likely, I think..However for 40 cms I think you will need a chainsaw.
That is what I thought.Loppers for 40cm diameter?? You’ve got bigger muscles th an me!
It really is very rough at the moment.Are you just cutting it neater to then seal and season for later? Does it really need that neat of a cut in that case?
What is your intention for after you’ve seasoned them?It really is very rough at the moment.
