best glue for felt?
disco_monkey79
5 Oct 2009
Hello,
I'm making a couple of trivets for a gift, and wanted to stick some felt ontthe back. Has anyone ever done this, and if so, can you recommend what glue works best?
I have some contact adhesive in the cupboard. However, I used this to stick the edging on my worktop, and in spite of following the destructions, it didn't adhere very well. Does the stuff go bad? I've had it a while (about 5 years), but only opened it for the first time to use on the worktop.
Thanks!
i used contact adhesive on suede/pig skin which worked fine. felt will be similar. I used the spray stuff from tool station, although next time I buy some i would go for one with a brush because i got it everywhere!
Hide glue or pva would also work.
I've used PVA every time I've stuck felt to anything (wood, card, other felt) and it's worked fine. Not even special fancy wood PVA - usually craft stuff. I have a hat made entirely from layers of stretched, laminated felt and that's just regular craft PVA glue that I think came from the Early Learning Centre a decade or so ago!
I'd expect it to be good for anything vaguely porous, but have problems sticking to non-porous things. Contact adhesive should be better for non-porous surfaces.
Pva will do it,just be careful it does not bleed through the felt ( to much glue or poor quality felt usual culprits for this ),alternatively you could use a can of spray on adhesive.
Yes, I use PVA all the time for felt. Put on a thin coat and let it go tacky them press on the felt and trim. Works great. :wink:
Exactly as Mailee says, a year or so back I made a card table and after asking advice here. I followed what Mailee and I think it was Roger advised and it worked perfect, and what's more us still stick there now.
~Nil carborundum illegitemi~
There is a craft glue...I think it's called Tacky Craft glue. I've had good success with it, with no bleed through.
marcros":f75kh3qa said:
can you still get copydex glue- that would do the job?
You can, but last time I tried it I really wasn't impressed. I don't know whether they changed the formulation or I just have nostalgic memories from my childhood or something!
