OPJ
Concrete floors - what the heck are they good for?
They're cold, damp, dull and when you drop something on them from any height, you know all too well you could be picking that back up again in pieces!
Fortunately, my problem isn't quite that bad, but the fence on my Makita biscuit jointer (90º, non-removable one) is now bent on one corner after a 1m drop yesterday! :x
In this first photo, it's the nearest top corner.
So, that makes it the top corner on the far side in this shot.
In case you still can't see it, this is the definitely the best photo.
Good news is that nothing appears to be broken. I can't see any cracks, splits or anything like that. So, what I'm wondering if I can simply bend it back with a G-cramp or similar?
I'd appreciate anybody's thoughts on how to fix this matter.
I only bought this in Febuary and saved £60 buying it sightly used on eBay (I assume that also means any warranty is out of the equation?). It's an almighty improvement over the £25 Ferm I used to have but, unless I can fix this fence, it looks like I'll be stuck with another biscuiter with which I can only reference off the base!
Thanks for your time,
Olly.
Olly.
