A_n_g_e_l_a
- Joined
- 25 Aug 2006
- Messages
- 96
- Reaction score
- 0
Colin,
A compressor is usually used to blow, but before it can, it first needs to suck. All compressors have an inlet of some sort. Sometimes they are many openings in a casting or moulding above a diaphragm. In that case they are no good for vacuum work. On the other hand a normal piston type compressor has a single inlet, usually with an air filter on it. Remove the air filter and fit an air-line and you have a reasonable vacuum pump. Certainly you have one good enough for veneering.
It is best if you fit an in-line dust filter too - as you won't want to gum up the works of the compressor.
Does the light begin to dawn? :idea:
PS I'm well impressed by the EZ system.
