RogerS
I was trying to veneer for the first time and ran into all sorts of problems.
I've tried to be succinct and also use words that might help subsequent readers in their search.
Groundwork - ply - sanded and brushed down.
Glue film and iron
Veneer - ash.
1) Cutting the veneer. I found the veneer very brittle. I sandwiched the veneer between a steel rule and a piece of scrap wood and then tried running my Stanley knife down. The veneer fractured as I went down the cutline and finally at the end of the cut, a piece broke off taking with it a chunk of the veneer that was intended for the finished item. I also tried a veneer saw but with similar results.
Is there a better way to cut the veneer to its initial rough shape?
2) Glue film. I read two separate ways to do this. One way peeled the film off the backing paper, laid the veneer on top and then proceeded to iron it all together. The second way ironed the glue film down first. I tried the first way.
First problem was the veneer not wanting to lie flat. It was still curled from being rolled up and I suspect that I should have flattened it first but would welcome any advice.
I read that you should spray the veneer with water. This I did but how much do you spray it? I found that the veneer rippled up over the surface and that these ripples have remained..most noticeably at the edge
The ripples in the middle of the sheet were of the same magnitude but have flattened out overnight. However, you can still feel them and I know that if I sand them out then I will sand through the veneer (which is what happened with my first attempt).
Did I use too much water spray? How can I get either stop ripples occurring or get rid of them once they've arrived?
3/ Splitting veneer. Some of the veneer on the roll was split but the split was clean. I read up on veneer tape but can you use this with a hot iron and glue film or do you end up with a sticky mess?
4/ As I was ironing the veneer down, more splits opened up..
Why did this happen and is there anyway to fix it other than inserting a separate piece of veneer?
5/ Ironing down. How on earth do you manage to keep the veneer to stay down while the glue is still soft? The veneer kept popping up all over the place and as I moved the iron to rewarm and apply pressure...another bit popped up !
6/ Repairing veneer. In my first attempt I tried to repair the damage caused by a split by inserting a separate piece. The book I read suggested cutting out the repair piece first. Laying it on top of the damaged area. Cutting lightly around the repair piece and into the damage area. Putting the repair piece aside, finishing the cut, removing the old material, scraping out the old glue and then inserting new glue film and the repair piece.
End result? You can clearly see the cut lines although I tried very hard to cut as accurately as I could. Are there any tricks to filling in the cutlines or do I just need to get more practice at it?
7/ Would I have been better off using a vacuum bag and if so, what glue do you recommend?
Really appreciate any suggestions and help.
Glue film and iron
Veneer - ash.
![edge-ripples.jpg](https://proxy.imagearchive.com/c32/c32f44cdabb1437f64bbb5cf01d1c058.jpg)
![split.jpg](https://proxy.imagearchive.com/891/891a02c843e5553f43897942264b7504.jpg)
![split2.jpg](https://proxy.imagearchive.com/2fa/2faf8e92c5d419b218b9dad1c24a5909.jpg)
