I've just took delivery of my first router (just starting out in woodworking) and am a little confused when it comes to setting the depth.
The bits I got have a little line on their shafts, which I'm assuming is a 'dont insert deeper into collet than this' line, however the manual that came with the router said to push bits in all the way before tightening up.
Now when I insert the bit up to the line shown on the shaft and then try and use the little scale on the router itself to set a depth of say 2mm the bit protrudes waaaaay more than 2mm, but pushing it in all the way gets it about right.
Is it safe to push it in as far as possible, or should I respect the line on the bits and just find a way to manually measure the protrusion when the bit is in place?
