I have a job to repair a rotten sill nose on a 1930s bay window. The central section (parallel to the front wall of the building) has extensive rot, and has been previously filled extensively, so I'm going to cut it away and glue on a new section with Lumberjack 5 min polyurethane.
Questions:
1. Do I need to do any joinery where the new section meets the two mitred 'wings' on either side of the bay? I was minded to do a straight butt joint, and use CT1 or similar, on the basis that the joint always fails due to wood movements, and at least the CT1 is flexible and provides a good seal. Is there any point trying to include a loose tenon or similar?
2. Accoya or Meranti? Both are available locally in suitable sizes, very similar price. I imagine the original is softwood, so I'm leaning towards accoya, not least as I need a project to try it on.
Any input extremely welcome.
Questions:
