rich1911
I need to replace the barge boards on two dormer gables. The originals are actually 4x2 timber with a tiny bit of moulding on the bottom edge. There is also a strip of moulding to cover the edge of the sofit boards (which are above the bargeboard, just under the verge).
I have seen some houses with quite ornate barge boards. Are these difficult to make? I have a laser cutter that can make accurate 3mm ply templates, but only up to about A4 size. I have a router, band saw and fret saw too.
Assuming I use 8x1 inch board, what's the best process to cut the decorative edge and pierced pattern? Rout out
I also need to make cladding for the front of the dormer gable and the T&G boards I took off had half round and triangular pointed ends. I guess these could be stacked and cut 3 or 4 at a time?
