Recky33
If I made the money they make I wouldn't be bothered if you called me Susanthe company actually dislikes the fact that everyone calls it velcro![]()
I used to share your concerns but have started using it more and more recently. As long as you don't mind waiting for the item/s it's no different to any other online transaction really. Whilst they host many sellers, the transaction goes through aliexpress and its all secure. You get very detailed updates on the logistics of the parcels and generally comms between the sellers is very good.I've never felt comfortable using aliexpress, just doesn't feel like a legit site.
Scrolling through amazon yesterday I came across this and figured that for £12.99 I can't go wrong
It arrived this afternoon and I'm not disappointed, at a minimum I've got a load of sanding discs, probably won't need the super high 800+ grits but who knows I may go down the resin route at some point.
Thanks for info. Due to be delivered today. I intend to use the very fine grades on my car headlights which have become misty and faded. The small size of the discs and with the backing pad in my drill it should be ideal and should save a lot of hand rubbing. Hope so anywayScrolling through amazon yesterday I came across this and figured that for £12.99 I can't go wrong
I have my Ryobi 2k inverted in a table works great and no problem with panel raising cutter 70mm dia ,Had mine for years dark blue modelThat's good to know. It's a bit too big for the stuff I'm into - I use a Makita laminate trimmer. However, toying with the idea of building a table and using it as a spindle molder.
I don't like using AliExpress either - all Chinese rubbish....I use eBay instead...!!!I've never felt comfortable using aliexpress, just doesn't feel like a legit site. My go to choice for abrasives is abranet sanding mesh, I can cut a sheet of that into a few discs that will easily be gripped by the velcro. Interesting fact, velcro is actually the brand not the product, the product is called hook and loop fastener, the company actually dislikes the fact that everyone calls it velcro![]()
£75 for that?! Very impressive, as someone who's owned the Nutool version that will serve you very well.
Thanks I hope so.£75 for that?! Very impressive, as someone who's owned the Nutool version that will serve you very well.
£2 at a car boot…just needed a new battery…guy thought it was some sort of torchView attachment 131598
