Inspired by the 100% ball/roller beraing quality of an earlier purchase, I thought I'd try the 4" belt sander from the same Silverline Hi-Spec range, available from Toolstation for just under £60, with a 3 yr g'tee.
It appears to be a (Chinese?) copy of the £200 Makita, with similar metal/plastic parts, even screw holes. The plastic is thick and rigid, matt finish - rather like my DW625 - and the metal castings appear of good quality, protected from an errant belt by ceramic inserts. The motor shows no signs of cost cutting. There is no feel at all of a 'diy tool'.
The belt runs with Makita like power at the same speed. Tracking is positive, and also like the Makita it will sand into a corner (belt flush with edge of tool). Certainly worth a look for occaisional use, helps put the most ££ into the key tools.
