MarkB353
Hi,
First post so I hope I've put this in the right place.
Problems with a Record RSBS14 bandsaw. I know it's a light weight machine but I've always tuned and maintained it and regularly use it to re-saw up to it's full capacity.... until today!!
Cutting some curves I heard a loud bang from underneath the machine. A quick search revealed that a lower bearing had seized and somehow been torn from its mount. New bearing ordered I decided to continue using the machine minus the one bearing.
I set it up and to cut a long story short, the blade is running parallel to the fence and it is tracking centrally on both wheels. The problem is the blade is pulling away from the fence. No tracking adjustments have worked. I've tried angling the fence both ways, same result, the work pulls away from the fence significantly, (10mm over a foot). New blade same result. I'll try and explain what i'm seeing. When I place the blade centrally in the cut the workpiece is parallel to the fence. it's as though the blade is being deflected away from the fence but parallel to it. Could the wheels be out of line?
Sorry this is a bit long winded. Any help would be appreciated as I really can't afford a new machine at the mo.
Thanks in advance
Mark
Thanks in advance
Mark
