Bandsaw table dust extraction
LarryS.
20 Nov 2007
Hi,
Has anyone modified their bandsaw to include under the table dust extraction ?
I’ve got a record 350 and have bought an Axminster adapter that gives me a 63mm output from the 4 inch port at the base, I’m just looking for inspiration on how to run / attach a pipe to end up just under the table by the blade
Any photos or ideas would be greatly appreciated !
Paul
Sent from my iPhone using Tapatalk Pro
Have you used the search function on the forum? This has been discussed seveal times.
In short, my own machine (12" SIP "heavy duty") came with a very good system made from plastic waste pipe by the previous owner (to connect it to a shop vac hose), just under the table. Sorry to say, the big port at the bottom is pretty useless (for several reasons). The DIY system is probably a bit noiser than a proper extractor (or at least the vacuum is old ans screams a bit), but much better.
If you have further questions, I suggest picking up on an old thread rather than starting a new one, as it keeps all the thoughts together so it's easier for others to find.
E.
PS: bandsaw designs haven't changed in many decades, so the solutions to the problem haven't either. It annoys me that those big ports at the bottom are still popular with the big brands, as they don't really work except on the smallest machines, unless you can generate a typhoon with your extractor (and even then there aren't enough holes in most bandsaws to get enough air movement).
I find this works fine Paul.
There's not much room under a BS350 so I found it needed to be simple.
    128 KB
I've modified my axminster 350.
I sealed off the lower 4" port completely.
On the angled higher port I cut a hole on the top side and built a box under the table. It works extremely well. If I tilt the table I have to remove the box, but thats only happened a couple times in three years.
I have pictures somewhere, I'll look them out.
The hose is 62 mm
This is the lift off box. There is a rear piece that stays in place. there are small magnets that hold the lift off to the rear wall.
    129.6 KB
    152.6 KB
I'm working on a new system myself, but the clearance under the SIP table is tiny. The previous owner raised the table on a big block to make space, but that brings other issues with it, so I want the table height back as it was originally.
I have a plan and a prototype, but it's not quite there yet. The table is cast iron though, which makes attachment reasonably easy.
Bob, I doubt the main port is doing much - I'd try to restrict it inside the lower cabinet so you just get fast airflow as close to the lower guides as you can. I think most of the dust capture will be your neat "hopper" arrangement.
E.
My Axi 310 has very little room under the table (makes adjusting the lower guides a pain) and the dust extraction is pretty awful.
Erik, the lower 4" port in the lower wheel cabinet has been completely blocked off. What dust does collect down there is easily vacuumed out something like once very month or so.
The higher angled port I'm using connects to a small compartment where the blade brush trys to clean the blade as it enters the lower cabinet.
The system works extremely well, even producing a suction at the perforated plate on the table. When i finish sawing and the blade stops, I can brush the loose dust on the table over the central plate and it gets sucked down into the system.
Brilliant thanks guys for the quick responses and photos, I very much like the idea of the made up box and magnets.
I’ll try it with the 4 inch not blocked first, but easy enough to change that if it turns out to be useless (I’ve got a 100mm pipe coming into it anyway which the 63mm branches off the same adapter).
Sunnybob where did you source the pipe adapters from ? Are they specialist dust extraction pipes or something more generic ?
Eric yes I did use the search function but found nothing , even though I know it’s been covered before, must be something wrong with the way I’m doing it, will need to try again
What Chris152 has posted above looks rather good, to me.
I saw a Rob Cosman video where he implemented something similar, using the plastic extension tube of a nomal vacuum cleaner, that covers both sides of the blade under the table.
It was a bit of a bodge, to be honest, but fundamentally not a bad idea and would work well with a bit of thought.
I plan to do something along these lines myself on my Axi 310, when I get the time...
I tried that method, it didn't really work well for me.
I tried the pipe elbow thing, very unimpressed. I even slit the elbow so the blade ran though the centre of the elbow. nah.
I used 100 mm to 62 mm adaptor (my extraction is 62 mm from the machines to the cyclone) and smoothed off the edges untill one was an interference fit with the other.
I made the box out of 3 mm ply, meaning to make a better one once i had proved it worked. But it worked so well the "if it aint broke dont fix it" rule was applied.
heres the actual adaptor modified, and the rear wall plate.
    130.4 KB
Sunnyb, which adapter is that ? It looks like a 63mm adapter to a flat plate which I can’t find anywhere ? Also a bit confused about your 100mm to 63 comment
Ah I think I understand now, you’ve got the 63mmpipe connected through the 100mm inlet port on a 100, 100 and 63 y pipe, with the 63mm cut off to draw dust through your adapter box ?
Wow that was hard to write !
The machine came with 2 x 100 mm ports. One at the bottom of the lower wheel box, and the angled one at the top of the lower wheel box shown in the first picture.
I blocked off the lower one because my entire extraction system is 63 mm and it could not work two 100 mm ports. At first I just had the 63 mm pipe connected to the angled 100 mm with a reducer from axminster, but the dust coming out from under the table was unacceptable. The machine came with an aluminium extrusion that covered the lower blade portion and "supposedly" guided the dust into the wheel box. :roll: :roll: didnt happen.
I use my machine most of the time with the garage door open and the wind blew all the dust everywhere.
Thats why I cut a 50 mm hole in the top of the angled port and built the 3 mm dust box. It works far better than I hoped it would. There is ZERO dust coming from under the table.
If I tilt the table I just lift the box out and accept there will be dust untill the table is squared again. but in over 2 years of heavy usage, thats happened less than a half dozen times.
The 63 mm hose runs to the rigid pipe and back to the extractor.
Thanks sunny that makes a lot more sense, I’m now trying to knock up something similar so will post photos when it’s done, currently stuck trying to find a 63mm connector that will attach to a piece of wood
63mm If I recall correctly is the diameter of guttering downpipe. I'm sure I used 63mm guttering fittings when I was building the dust collection for my mitre saw station.
Thanks to everyone for the advice, I managed to get the 63mm attachment, found some pipe that slotted into that to put the extraction right next to the blade.
The pipe turned up in my dads garage which he used to keep fishing rods in! I saw it, thought that it looked about right, and slotted in perfectly
Thanks again for all the tips / advice
