RobertMP
I think it is time I got a bandsaw. Can't say I'm certain about it but it seems like a good idea
My next project is a sideboard type unit which after test pieces SWMBO seems in favour of unsteamed beech. Think 1400mm long 3 door kitchen cupboard with flat panel (is that called shaker style?) doors + 3 drawers. I'd be starting with 1" sawn from the timberyard and have been puzzling over how I will get thinner panels to inset in the doors without wasting a lot of wood and effort thicknessing down. So the idea of resawing the planks came to mind and hence a bandsaw.
I'm guessing a bandsaw is the sort of thing I'll have more use for when I've got it sitting there plus it is bound to be useful as my turning progresses. I have an old elu table from a dead flipover saw which has a bosch circular saw under it for ripping normal thicknesses and may get a proper table saw sometime too but no hurry for that as it does the job.
Anyway bit of a ramble there. Is the SIP a good choice? I only picked it because it has a bigger motor power and can take 1" blades. I recon 200+ mm depth of cut will be plenty. I did search the forum as best I could and found only good comments.
Finally if anyone has the SIP could you tell me how big the base footprint is? I'm planning to pull it out a foot of so for use then push it back after and it would help to know in advance how much space the base needs.
Oh and it is £435 on ebay delivered here.... any better places?
