Hi tsb,
1, extremely useful
2, resawing, ripping, cutting curves, cutting tenons, cutting veneers, dovetails, etc. You name it....
3, A number of factors can affect accuracy, eg type of blade: a wide blade will cut straighter than a narrow blade. Tracking, blade tension and fence alignment will also affect the accuracy. If the saw is set up properly and the correct blade is used, then it will cut straight.
4, The finish is dependant on the type of blade. The tooth count and type will affect the finish. Feed rate will also be a factor. Again though, if the correct blade and feed rate are used, it will leave a rasonable finish. However a bandsawn surface will always need cleaning up by planing or sanding.
5, Except for ripping and crosscutting, where a tablesaw excels, a bandsaw will do much much more. See the answer to question 1. The finish from a tablesaw is superior. My tablesaw is the centre of my workshop, it is used in every project.
HTH
