Thick work piece on a small bandsaw is hard going. The experts say you should have around 3-5 teeth max in the work or the blade cant clear the sawdust.
14tpi and 80mm is more like 50 teeth in the work. However, for bandsaw boxes you dont have much choice as a coarse blade will be too wide for the curves.
