Honest John
So I'm thinking of a change of tack and having a go at a bandsaw box, somnething ive never tried before. What size of blade do you bs box makers use? I've searched the forums and there are many differing opinions. Alexam and at least one other is using the carter blade guides with 8th inch blades with great success. Are quarter inch blades ok to use for the less radical cuts? My SIP bandsaw uses roller bearing guides so I can't use the the Steve Maskery mdf disc and double stick tapetrick without some further re engineering. Woodpigs use of a grooved bearing looks kind of interesting and might be worth me investing in one, but it isn't clear if other engineering work is required beyond just fitting it as a thrust bearing. All these mods are unrequired I guess if the job can be done with a quarter inch blade. I'm sure I saw a post some time ago in which someone suggested a 3/16th 4 tooth blade was the dogs for this task, and yet others have suggested14 tooth? Be nice to know what to use. I recon I could track a 3/16th blade with my current guides, although the handbook suggests 1/4 is the smallest that should be used.
