galleywood":2roul1cp said:Have you dressed the back of the blade with a stone?
No, I can't feel any burrs or anything there.
paulm":2doij3s7 said:I've never known teeth to get burred over, lose a bit of sharpness but not burring, what have you been cutting with it ?
Ttrees":2srpth6p said:Well the bog oak could have stone deposits, and particle board sometimes contains nails as it it often made from recycled pallets and such.
Maybe it could be one of these factors?
Tom
Noel":rdjc163k said:Been using Tuffsaws blades for some years, best blades in my experience for sharpness and longevity. I cut a lot of recycled timber with hidden nails and staples, current blade still going strong after 3 months or so.
Rorschach":53l5fpgq said:Noel":53l5fpgq said:Been using Tuffsaws blades for some years, best blades in my experience for sharpness and longevity. I cut a lot of recycled timber with hidden nails and staples, current blade still going strong after 3 months or so.
What blade exactly are you using though? an M42?
Noel":2sfrkean said:Rorschach":2sfrkean said:Noel":2sfrkean said:Been using Tuffsaws blades for some years, best blades in my experience for sharpness and longevity. I cut a lot of recycled timber with hidden nails and staples, current blade still going strong after 3 months or so.
Bi-metal blades along with the Sabrecut or Supercut premium (not sure which), 1/2" 3 TPI mostly, would need to look up the last order. I've never had teeth "burr over", certainly will lose sharpness over time but with a well maintained and adjusted BS, I've never used better blades.
As suggested you should contact Ian or Susi, always very helpful.
Is this after you have been cutting a lot of curves?Smithy":3rmqorgu said:....... At first I have found them to be wonderful but I find they quickly deterioate
Smithy
