Looking for some clever ideas to help me improve my bandsaw blade changing. I have an Axminster Awhbs350n (I am pretty sure that's the model number), anyway it is the forerunner to their current 350 model:
http://www.axminster.co.uk/axminster-ho ... saw-508206
The difference though is that the current model has a slot in the side of the table for changing the blade whereas mine has the slot at the front of the table. Now while the front slot makes inserting and removing the blade a breeze, I have to remove the fence guide to do so, which is not such a breeze.
Anyone have a clever idea for how I could change things so I don't need to remove the fence guide, the current setup means I am loathe to change blades as often as I should and though I know it's wrong I often use a dull blade for longer or an unsuitable blade for the job at hand because it isn't worth the hassle to change for just one cut. If I didn't need to remove the fence then blade changing would take seconds and I would do it much more often.
Thanks in advance.
EDIT: Mine is actually the 310 model, I don't think they do a current equivalent, but anyway, the saw is essentially the same design as above, just smaller.
Thanks in advance.
