jrm688
I use the EZtension gauge. It’s reasonably priced and easy to use. The centre bolt is set for the blade width using the included jigs. As you tighten the blade one of the magnets pops of when the tension is right.
From the above it would seem that those with 'big' (1" +?) blades are bothered?
For (a majority?) using lesser sized blades, is 'about that' good enough?
The confusion over metrology is ... confusing. ;-)
Tension (lengthways) torque (twisting) torsion (twisting).
A lesser sized blade, what might be honestly suitable for a machine which won't compress the spring fully, likely is getting past 15K PSI from what I can make out.From the above it would seem that those with 'big' (1" +?) blades are bothered?
