Bandsaw blade alignment tester
GrahamRounce
UKW Supporter
26 Jul 2007
Bethnal Green
No big news to anyone probably, but I found it useful: A piece of wood held against the blade by a small magnet glued to it. Saves making test cuts.
Thanks Graham - that is certainly useful to me...I've just fitted a Kreg fence to my record 350 and need to align it.
Dave
Oddsocks,
See you have a Kreg bandsaw fence. After a few days/weeks use any chance of a review. I'm considering fitting a new fence to my Startrite to replace the homemade one.
regards
Alan
beech1948":3bwbp46y said:
Oddsocks,
regards
Alan
will do - I can't use the garage at the moment as the up and over door is broken (bits on order). I'll take some pics as well, the Kreg took some thinking to fit and allow blade changing without removal
It's still a good idea, but might I suggest...
... two identical strips, wide enough to cover, say, four teeth vertically, but thin enough to be springy, glued together at one end for a couple of inches.
Slide onto the back of the blade until it's positioned about half way along, then hold the open two ends together with a bulldog clip or elastic bands. The kerf error ought to cancel out.
But it's only a starting point really - under cutting loads it will be different.
Cheers,
E.
