Fred Page
Would somebody give me a quick opinion?
I run a Startrite 352. Am I asking too much of a three eighths blade to cut 4 inch square ash?
Although all settings are perfectly adjusted to square - and this shows when cutting say one inch stock - as soon as I cut 4 inch quare the cut simply goes out of square. Is this the result of using a narrow blade? Am I expecting too much of this blade? If so, what is the reason? I should add that with this narrow blade I only run at medium tension - should I up the tension and would this help? OR THE OBVIOUS - use a wider blade?
Fred.
Kington in Herefordshire.
Fred.
