TobyB
I looked at a couple that had a cup shaped blade a bit like a ring cutter (e.g. http://www.willyvanhoutte.be/en/catalog/show_cat/446) and at other designs which used simple scraper tool like some hollowing systems (e.g. http://www.laymar-crafts.co.uk/tip48.htm) - but the one I have has a bowl gouge-like cutter mounted at about 45 degrees. It seemed to produce a better surface. I made some balls out of (American?) tulipwood and it still generated a lot of tearout but those sanded OK. Some beech balls worked out better, and I made a nicely smooth walnut ball that needed very little sanding. Maybe well set up in the right hands a simple scraper-cutter will work ... Holtzapffel illustrates ivory billiard balls being made that way ... but I'd try to make a ball by hand using gouges rather than a scraper, and all of the instructions on making them talk of such tools as well ... so to me it makes sense for a jig to try to work like that too.
Maybe an expert who know what they are talking about will join this thread?
