Dibs-h
Rog
Could you copy from a card to a USB stick?
Dibs
Dibs
Dibs-h":w1cfpje4 said:Rog
Dibs
RogerS":1nwg9cbe said:Dibs-h":1nwg9cbe said:Rog
Dibs
Don't you need a computer between the two?
Dibs-h":3hs55wp2 said:RogerS":3hs55wp2 said:Dibs-h":3hs55wp2 said:Rog
Dibs
Well - the webpage for that widget says you can connect via USB - so was wondering what would happen if one end was the card in the widget and the other a USB stick?
RogerS":3gj77nta said:[ I tink that the USB cable is simply there to allow you to use it as a normal card reader when connected to a PC.
Yes you do. But then you might as well copy from a card to another card. USB stick is the same thing in another shape.RogerS":c1jfmnec said:Dibs-h":c1jfmnec said:Rog
Dibs
Jacob":2vr70g7s said:Yes you do. But then you might as well copy from a card to another card. USB stick is the same thing in another shape.RogerS":2vr70g7s said:Don't you need a computer between the two?Dibs-h":2vr70g7s said:Rog
Dibs
If you just want duplicates for back up what about just taking a card reader and a lot of cards then just take pot luck on being able to find a computer?
Where are you going BTW? Wales again?
NB a card reader is just a simple adapter with a socket for the card at one end and a USB connector at the other.
Webby":2gim9mcp said:to save all the problems .....and the hassle of downloading cards..... just buy more cards they are so cheap now and shoot in
high j-peg (download when you get home)
this will give you enough resolution to print out to a A4 print that has quality ......anything higher than high j-peg in my
opinion is a waste of card space ....i dont know of any one apart from pros that would print out to poster size so would need
the extra Raw files etc
Dave :O)
