woodbloke
The back panel for the chest has gone in this morning without a hitch...an elm frame with bridle joints at the corners and a pair of bookmatched elm panels. The frame is 14mm thick and is set in just a fraction under the surface of the carcase, if you look carefully at the top right hand corner on the rebate you'll see where I had a bit of 'wobbly router syndrome' :x , but never mind, hardly shows. Finish is two coats of matt (I don't like a shiny finish though a satin version is available) Osmo-Polyx oil which is, now I've tried it, absolutely fabulous stuff. Simply apply a thin coat, take off the excess, let it dry overnight, repeat a second time (no need for subsequent coats etc) allow to thoroughly dry and buff with a duster....sorted
. Will be my finish of choice from now on for this type of project - Rob
![](https://proxy.imagearchive.com/185/18570fa374ccabde3ede00ae1a64a045.jpg)
