Back Panel - WIP Installation Pics
woodbloke
13 Apr 2006
Salisbury, UK
The back panel for the Elm Cabinet II has been polished and has been glued up into the carcase:
I used some small bits of cushion flooring under the cramping blocks as they were going onto a polished surface:
As the inside was finished and waxed I could afford to leave the glue to harden off and then it could be picked off with the point of a scalpel:
A shot of the back showing that there's no damage caused by the cramps:
and a final shot of the finished interior showing the bookmatched panel:
which has been finished with a couple of very thin coats of matt Osmo-PolyX with a good application of teak wax over the top, polished off with a soft duster - Rob
That's gone together really well, Rob. You must be quite pleased after all the problems you had with it - which I don't think any of us would have guessed if you hadn't mentioned them.
Cheers :wink:
Paul
Very nice and thanks for showing us, good idea with the pads for clamping, what are the 2 holes for just above the bottom rails on the inside for, sorry to be nosy but I just have to know :lol:
regards,
Rich.
