Paul Chapman
Hi Richard,
Welcome to the forum.
Cheers :wink:
Paul
Cheers :wink:
Paul
ivan":26zbjwiy said:It's a pity that there is not more actual evidence relating to hand plane cutting action,
matthewwh":19r9mdh9 said:It is indeed.
The Mk2 version without the spring loaded pin, although you can still hone skewed blades with it by adding a shim between the edge of the blade and one of the locating pins.
The wedge is shopmade; they don't come with one but it's only a few minutes work to make one and you can do custom wedges for the different thicknesses of blade that you want to sharpen.
The main thing that I like about it is the accuracy, the two little steel pegs that the blade locates on keep everything square in the lateral plane; so as long as you get the projection right, it is very easy to get exactly the same setting time and again. Also the broad wheelbase means that the guide and the glass plate are dictating to the blade, not the other way around.
Tony":3dhjua4e said:How do you keep everything so clean?????? I would love my sharpening kit to be that clean :shock:
Rich":gu2p4unb said:No but they are better at multitasking, so I'm told at least once a day :?
