Axy AWFS 18
Hi Edwin...
Go ahead with getting one you will be delighted with it ... stage 3 involved getting another one to use as the bottom holder, (you have to swap the turn and the screw to the opposite sides cos your using it up side down.)..
So if funds will stretch to it get 2, as it will mean an end to having to use any of the stupid old style clamps .. even if you don't go further with the stages you will be happy.
Stage 2. 'Mikes knob' is icing on the cake and is not totally necessary (unless you have arthritis in your fingers / hand or want to make releasing / clamping even faster, or just to look cool when doing videos.. lol)
Stage 3. Will be replacing the bottom blade clamp and also a holder for a different method of holding it
( the fettling required... is removing 6mm from the post of a new aluminium part, this then allows the standard
top clamp rigid with bottom floppy or / top floppy and bottom rigid or maybe both top and bottom not floppy or rigid)
Stage 4. Fettling to gain better advantage of stage 3
Stage 5. Fettling to gain full advantage of stage 4
