Axminster at260spt planer thicknesser setup HELP!!
To get the tables level and co planer you do need a decent straight edge, your end results will only be as good as the straight edge you use. I purchased the Veritas one from Fine tools on @MikeK 's recomendation and it makes things easier along with some feeler gauges. You can now get it from
https://www.axminstertools.com/veritas-aluminium-straight-edge-1-270mm-50-474735
Yea you are bang on with that. I have the exact same straight edge and it's great. Also got a set or feeler gauges which are a great help too :)
