scooby
Axminster Craft series Lathe. AC240WL
Most important thing to mention, there is NO tailstock. This lathe was mainly used at my day job workshop as a disc sander or for small chuck mounted work, the tailstock casting ended up getting damaged in storage.
Whether a replacement can be obtained or a home made solution be made, I'm not sure. I've included the MT2 quill and advancing wheel if someone fancies a go at the latter. Also included is the original faceplate and an Axminster evolution tool post (16mm) which was used with the Axminster mounting table when used as a disc sander. I've kept the table for my home lathe so that isn't listed.
Lathe details
https://www.axminstertools.com/axminster-craft-ac240wl-woodturning-lathe-105118Tool Post
https://www.axminstertools.com/axminster-evolution-series-tool-post-16mm-x-90mm-101831
The lathe was purchased Feb 2020, it has been used quite a lot but is in good working condition. Bit of surface rust on the bed ways, not too bad.
Item will need to be collected from Greater Manchester.
£100
Lathe details
£100
