AW106PT & FOX PT chain problem
OLD
9 Aug 2004
nantwich
Just had the chain break on my fox m/c , axminster can supply so will soon be fixed .
But why did it break ,well the chain wheel fixing screws on both rollers were loose and the infeed drive was loose on the shaft also the fixing screws on the small cog that screw from the back were loose one almost out ,lucky to get away with a chain i think.
I there for i suggest to all owners of the above to check these fixings out when you oil the m/c perhaps.
I think the extra end float from the loose i/f wheel caused all this but its got to be worth a look.
