Having a bit of a workshop rearrangement and ended up moving the compressor. Where its located now would make it a tad more difficult to get to the drain valve on the bottom to let the moisture out. I stumbled across this.
I never knew such a thing existed. If it does work it'll be £16 well spent. You can set how often the valve opens (0.5 - 10 seconds) then how often it opens (30 seconds - 50 minute intervals) I'm waiting for an adaptor to allow it to bolt into the existing compressor hole, I'll report back then. Just to add there are other brands available with varying prices. If this one turns out to be a flop I might have to try a more expensive one.
Sent from my SM-G960F using Tapatalk
