fasterbyelan
Having just received the 10 piece set of Ashley Iles Butt Chisels, a quick visual look at them shows that the all the wider ones have been ground with a skew, the worst case being around 1mm. Whilst I expected to spend some time preparing the tools, I would have thought the manufacture would have been able to grind the cutting edge square to the sides. Am I expected too much?
As I will have to correct this by hand it will add significantly to the prep time.
Regards,
Karl
PS Can add photos later if required
Regards,
Karl
