Ash case.
Paul.J
27 Sep 2006
Birmingham/England.
Heres summat i haven't made in a long while.
A couple of weeks ago i was asked if i could engrave initials onto a wooden musical ball made from Beech,i was reluctant to do it as the ball was finished and was to be given as a christening gift,but the couple had tried various people and they also refused to do it so i was talked in to doing it,they would take full responsilbility if i messed it up that was made clear to start with.
After some practices and sending images of what i was trying out they like the pyro'd effect so thats what i did and must admit it did look good.
The ball was in a cardboard box and when they picked the ball up which they were very happy with i was asked if i could make a wooden case to present the ball in and this is the result.
They liked the Ash wood idea,good job as thats all i had cut up to use :D
The corners are mitred,the top and bottom just glued straight on finished with sanding sealer and carnuba wax polished on the lathe :lol: and lined with a cream satin.
    40 KB
gregmcateer":o00o6aij said:
Very neat, Paul.
Do we get to see the ball, too?
+1 when you apply the wax do you use a smooth cloth or a rough rag like a scouring pad? and do you 'force' the wax on or simply rub it over the surface?
Baldhead
Thanks both :D
Sorry no piccy of the ball :(
BH-I put the hinges on first then removed them, then used the chestnuts buffing wheel to polish the case up while it was in two halves,then put the hinges back on.
