Recently made this bench. Legs are 45mm diameter tapered to 35mm, into 41mm diameter epoxied and wedged through mortices, top is 44mm thick. Bench is 350mm deep, 440mm tall, and 1800mm long. I epoxied them to ensue zero movement of legs in the mortices.
The bench flexes along its length ever so slightly when two people sit close together in the middle. You can deflect the legs somewhat under reasonable pressure. I did quiet a lot of experimenting when building it and although thinner legs and smaller mortices would have, I think, been strong enough the flex would have made me concerned each time I sat on it. With legs twice the length on a table I think it’ll wobble and shake no end with even light use.
