Hi,
This is my first post. I have lurked for a while and seen some 'interesting' threads as well as some very informative ones. I will keep away from the 'interesting' ones for a while
Anyway, I'm getting more involved in woodworking as I've moved from London to North Yorkshire and have the time and scope to do more, I also now have a garage which is mine, all mine!
My knowledge of wood working is limited to what I learnt at school (which was very little), but I'm having to do more and more, so I need to start to learn. As part of a separate piece of work, I have just printed and built a CNC machine and am using that, originally that was aimed at a narrow market of foam cutting. See here for my trials and tribulations (
New build in Clapham, North Yorkshire, UK).
After I built the CNC machine, I got a number of requests to do free sign engraving, so have done a number of "No Dogs" signs for the park and similar. I've glued two planks of wood together to make the sign high enough, flattened the surface and carved the letters out using a 2mm router bit. I spray paint the letters and then do a small 0.1mm pass over the surface to remove the excess paint, cut to size, varnish and then give them to people. This is NOT a commercial venture and is helping people out.
Anyway, as I am doing more woodworking, I thought I'd try and learn more about the tools and how to use them correctly and hopefully avoid burning the garage down, or losing a finger, or leg or killing myself. All of which are likely with my lack of motor skills.
Whilst many of you probably never even think about simple things such as cutting a piece of wood square, this is a major piece of work to me as I never, ever seen to get it right. It's never clean and almost never at right angles and never vertical and never wholly straight. Apart from that, it's pretty perfect
So I wondered about getting a tenon saw and using that, but then I looked around and discovered that there are as more tenon saws than I ever thought possible. There are even Japanese tenon saws that look like nothing I've ever seen. There are different lengths, different teeth per inch (why not metric?), different handles, brass backs, plastic backs, wooden handles, open handles and the views range from rubbish to brilliant for every saw. Apparently most tenon saws need to be sharpened before use according to a highly respected poster on here. That actually made me gulp, I have no idea how to sharpen a saw and am genuinely scared to even consider it. I then saw the price range of the mass market (£10-£30) and then saw that people recommended Veritas saws, so had a look at them and thought, Wow! They are expensive.
So my simple question is, can somebody recommend a decent (tenon?) saw for making straight cuts across wood 300mm (ish) high, that makes straight cuts, is easy to use, doesn't require sharpening and is safe for a muppet such as myself to get the hang of and use. I'm drowning under data and need to get some air. Oh, and are the Veritas saws worth it? I happen to have an antique centre down the road which seems to have a lot of older tools in, never bothered before, but are they worth looking at?
Many thanks
Rob
