wonky_phil
New member
I strongly suspect i've been using my Dremel with the plunge router attachment for bigger jobs than it was intended for. As a result it's probably a good idea to buy a proper router.
My question is, are the sub £100 routers worth getting? I very much doubt i'll be routing counter tops, it'll mostly be plywood and if I use it more than once a month i'll be suprised. Therefore I don't see the point in spending £300 on a router if a £60/£70 one will do - however, if the cheap ones are just plain rubbish, regardless of amount of use, I don't necessarily mind spending £300 on one.
Any advice would be much appreciated.
Kind regards,
Phil
Kind regards,
Phil
