transatlantic
Boom!
Just wondering what people here do.
Do you apply glue to both sides of your joints or only one? .. or it depends.
Although you always hear people saying that you should, and although I've taken that advice, .. it's always struck me as being overkill? Surely if your joints are tight, only applying glue to one side (and then shifting the boards back and forth to further spread it) should be enough as it's going to spread when you tighten your clamps?
The only reason where it seems to make sense is when using those glues that you apply to both sides and then let sit of 5 minutes before making contact between the two.
The reason I ask is because life could be made much easier when using the fast drying glues. (I know that there are slow setting ones out there)
Has anybody done any experiments with this? using one of each method and testing the strength of the joint?
