woodbloke
Having had Bob9fingers saw up some timber for me last weekend, this latest project is under way. I started on the two ends, stuck them together in the AirPress, lipped the bit going on the floor and then planed them to size and dead square.
I'd already prepared the veneers so it was fairly easy to:
shoot them in with 'Big Woodie' after which each 'lay up' can be made with masking tape (to pull them together) and veneer tape along the seam:
Slap on some TBIII, pop them into the bag with plenty of thick paper on the edges and corners, apply a bit of suck (the needle is well past the stop, so it's pulling a good vacuum:
and it should be cooked by the time I've finished the vino :wink: :lol:
You'll note that although the AriPress pump is great, the bags, especially the seal bit, is not quite so good ...in fact it's rubbish - Rob
