Apologies if this has been covered elsewhere, I couldn't find anything definitive.
I made a spur of the moment (doing a lot of that lately - grumpy old man retail therapy) purchase of a Ferm FLZ -275 bandsaw for £30 on Gumtree. Nice fellow, honest chap, no issues at all with the buy.
Got it home, tinkered/cleaned it the next day, and the upper tyre disintegrated. A few days later the bottom tyre, which had been resolutely fine, followed suit. It was a shed workshop item, and I've brought indoors so I guess the warmth expanded the pulleys, which coupled with old unelastic tyres meant they split.
So - as far as I can see, tyres are way overpriced at £15-20 or so each, and I may as well have bought a new saw at that price. I fiddled with a vacuum cleaner drive belt, which would have been perfect if longer and wider, but they aren't sold by dimension, and in any case are unlikely to come big enough. Checked out loads of flat fan/pump/car drive belts, several look like good candidates, but again no clear dimensions.
I might try a motor factor, but I suspect they'll snort. The next option is an inner tube. Anyone tried a glued on strip of bike inner tube? I've seen a full split inner tube used on big wheels on the internet, but these are only 8" diameter or so, and the tube will need to be a cut strip, rather than the full circumference. How do you make a perfect join, and do you need more than one layer? and what glue?
Then I have also seen insulating tape used. Seems very temporary, but again how many layers, how precise does it have to be? Ditto with masking tape (seems the worst option to me).
Anyone had success with a diy fix that isn't silly money?
