sploo
Somewhat extinguished member
That looks really good. I've got a similar style of motor + impeller, but eject the exhaust outside into a hopper (no filters). I have wanted to build a Thien or cyclonic separator but have never got round to it.MattRoberts":3q78pki1 said:Depends what your definition of compact is. I have a single garage, so I bought a 2hp extractor and built a thien baffle. It's pretty compact considering the power.
My only concern with your setup would be the filter on the exhaust - I suspect that's not enough surface area (it'll be restricting the airflow). Could you use some 6" hose to run the exhaust outside (with no filter)?
A big problem with most machines is that, even if you have a capable extractor and good ducting, the design of the machine may still be poor for capturing dust. With my 3hp extractor and large ducting, I can "steal" a chunk of wood from a bench that's a good 7 meters of ducting + 1.5m of 4" hose away from the extractor; but the bandsaw that's connected to that hose will still drop dust onto the floor.giantbeat":3q78pki1 said:i had not thought of just using a respirator, i just acquired an older axminster air filter, though i original wanted to reduce the amount of dust kicking about the room (the 26" spinning sanding disk kicks it out big time), this might at least be the best option for keeping me safe.
thanks Sploo, looking at my space issue from another angle now.
My attitude then is that the extraction is mostly for preventing the worst of the visible dust, and will help me clean up dust and chips afterwards. The respirator protects me when I'm doing anything remotely substantial (because with the best will in the world there will be dangerous fine dust in the air). The air filter then helps to catch the fine dust that would otherwise stay in the air for hours afterwards.
After installing the air filter I did notice a reduction in dust "smell" when I re-enter the shop after a few hours (because you usually kick up the fine dust that's settled).
This page is over 10 years old, but details my solution: http://spikyfish.com/DustExtraction/
If you really want to melt your brain by learning a huge amount about extraction, then there are few better places than: http://billpentz.com/woodworking/cyclone/index.cfm
