Doug71
@Phil Pascoe just out of curiosity what don't you like about your jigsaw, it was the ps300 body grip style you got wasn't it? I have the same model, I don't really use it that much but never had any problems with it.
There's a very simple solution to your problem. Buy the Makita.
I found their customer service to be non existent so refuse to buy another.There's a very simple solution to your problem. Buy the Makita.
Yes. I find it awkward to use and the switch to my mind is so badly placed and difficult to use as to be dangerous - it's near impossible to switch off quickly. A trigger is far better. I would consider the three Boschs and the DeWalt that preceded it to better designs.
Think you’ll find the base of the Kapex saw is made from cast Magnesium used to actually make the saw lighter & easier to transport, so rather than being made from less material it’s made from a more expensive material to make it lighter, another reason it’s a more expensive saw.For me the weight of a tool is an indication of quality, lightweight means less material and you are getting less material for your money and something heavier remains where you put it.
You seem to be wasting time. Buy the Makita. You clearly don’t want to buy Festool. I have the Kapex and am delighted with it.I did notice the Festool Kapex 60 had a big knob on the rear to unlock for bevel moment which seemed a bit backwards in design, even my Bosch GCM 8 has a lever on the side that you just flip
That is only because you have a 12 inch blade, had you brought a 10 inch then by now you would have found a need for the 12 !!I've never had to make use of the 12" blade,
I bump the blade into the workpiece on the waste side for starters. The small mark made by the tooth shows me exactly where the cut is going to be. I can then tap the workpiece along a bit. TBH I cant see the laser thing giving a level of accuracy as the line is quite wide and not as clearly defined when you bring the pencil mark up to it. But maybe thats just lack of experience as I've not used a laser equipped version.Also on my kepex 60. I bought the option guide light. So when making cuts you can see where the blade will land. Some people prefer it to a laser.
I knew a few guys who used all Dewalt gear including that saw but in a workshop it still has the rails poking out the rear.I recommend the Dewalt 780
Which model do you have?Do you want something that’s truly accurate more versatile and considerably cheaper and better built that either of your two options?
It’s a little bit bigger foot print than either, but I’m guessing your going to be be putting it in or building some form of permanent cabinet which jeans that the foot print won’t be too much different.
My suggestion also doubles up as a very handy bench and has fairly good extraction.
Have I tempted you?
Look at the Wadkin radial arm saws. Absolutely superb bits of kit. I have one and it’s the most accurate piece of kit I own. RAS saws have a ‘reputation’ which for some models is well deserved. The Wadkin is a battle ship and doesn’t flex. They are dirt cheap to buy.
BRAWhich model do you have?
