Mark A
Question to all those above who say jigsaws are no good for straight cuts - have you only used cheapo machines?
I started off with my father's old crappy Black and Decker, and when that melted cutting a chipboard worktop I replaced it with a Mac Allistair from B&Q. That was so atrocious I swapped it for a Ryobi, which was no better. Eventually I bit the bullet and paid for a Bosch Pro: the difference is night and day - produces good perpendicular cuts up to about 2.5" in softwood without any problems, and with the right blade can cut up to 5" with only minor wobbles.
Sunnybob - Try some thick, ridgid blades; they make all the difference.
I've had good results from both the Bosch Precision series (cheap) and the Festool Trion series (expensive).
These work well
When jigsawing, it's imperative that you take your time and let the tool do all the work. Also, applying force in any direction but down and forward (gently) may induce wandering, especially if the blade isn't held perfectly parallel to the side of the base plate.
Let us know how you get on!
Mark
These work well
Mark
