Scottlefley
Hi All,
Right finally found some time to think about making a table saw router table workstation...not another one i hear you all cry! After spending many hours looking at the other fantastic workstation build i have taken various ideas from these with the primary difference being that i already have a trend PRT router table so am going to attempt to incorporate that into the build. I Ummed and ached about selling it on and buying router plate, fence etc, but once you add up the cost and added complexity it didn't seem to make much sense for my needs. Also i am going to try and o this on an absolute minimum budget, can never really justify spending lots of materials for building stuff for the workshop when there is always a new tool i need/want!
So i had stroke of luck for the base of the workstation, many moons ago we replaced our settee and was left with a large leather footstool, not being one to throw anything away willingly i stripped the leather of the stool and kept the rather robust base it was made of...turns out this is pretty dam near perfect size for my build! Added a little extra strength internally to it, but with castors fitted it will work fine.
So next i wanted to build a base for the ts200 to sit on, again trying to use any materials i have laying around int he barn, i found some 18mm ply, two offcuts, which when measured would be just about enough to build a box so fortune strikes again...so far zero expense!!
This isn't attached or anything yet as i am now thinking about dust extraction, was thinking of taking the mesh off the bottom of the saw and then making a large opening in the box to let all the dust fall down into and attached the vacuum to the box, as seen done by many others...any thoughts or gotchas to watch out for this approach?
Anyways, ordered some castors from fleabay so total expense for build thus far is £15....missuss is very happy with me thus far! 8)
