MattRoberts
I'm guessing your edges are no longer at right angles to the top and bottom faces - you've effectively got a slight parallelogram. If you plane the left edge (at the top, where it meets the top face) it should come back into square. You can then check the opposite edge is parallel ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
