Another loft insualtion question
whatknot
29 Jul 2017
Cornwall UK
My daughter is about to have her loft insulated, and as the boiler is up there it will require a walkway and she wants some storage for Christmas decs etc
I am getting conflicting advice on the following, when adding walkway/storage over the insulation, do you need to leave a gap between insuation and boards? or no gap?
Some say leave a gap for ventilation to stop condensation, others say don't leave a gap for the same reason
Which is correct?
AIUI, the minimum depth of insulation is roughly 200mm, which is more than the joist depth.
Thus any walkway you make will need something between its underside and the top of the joists.
Sorry if you know this already, but you can use that as a stepping stone to answering your question.
There are many products available to do this (loft legs). We had a discussion on it a few weeks back. The length of commercially-available legs could tell you where the board sits relative to the top of the insulation.
Shoot me for this, but if you're retrofitting, you can put in as much insulation as you find cost effective.
In an area of loft that I use a lot for storage, I screwed some 2x2" timbers along the tops of the joists to increase the depth, laid 2 new layers of 100mm rockwool between and dropped the flooring chipboard down on top. It's s great deal better than the couple of inches of blown glass wool that the house originally had.
The loft space is well ventilated and gets stinking hot in the summers. I don't find an issue with damp.
Insulation settles under it's own weight and time, so you'll likely end up with a gap anyway.
I don't get the impression that loft legs are very stable for regular foot traffic and if so, only if the boards are secured around the edges so that they can't move sideways.
It was I who instigated the thread on loft insulation & walkway/storage
The suggested depth is now 270mm, but the depth we are having is 300mm, loft legs were discussed and decided against in favour of using timber to raise the walkway/storage areas to 300mm, but the conflict is some saying leave a gap (so say 310mm) or just 300mm no gap
There is very little insulation at present, it appears there was insulation but the previous owner pinched it
As I just replied to another, we are going for 300mm, loft legs were an option but decided against in favour of timber
We moved into a new build bungalow in Sept 2022. It has 200mm deep ceiling joists We have 400mm of rockwool insulation across the loft, except the 6x6m area I had boarded for storage. Under this is 200mm of Celotex foam insulation.
Colin
My main concern is that if the loft space is better insulated, you need to be confident any pipework and the boiler are adequately protected against freezing. In fairness having the boiler up there probably mitigates the risk somewhat!!
I was quite surprised to find the boiler up in the loft but apparently it isn't that uncommon
And yes all pipework will be thoroughly lagged and boiler will have a froststat, boiler is being replaced at the same time as a new roof, then insulation then boarding
Colin
This is a 1940s/50s bungalow, ceiling joists are a mere 75mm, but thankfully are supported for the most part by brick walls where they mostly need to be
I would think about insulating the roof itself if you are replacing the structure. When I rebuilt our bungalow we added a higher pitch to give us a whole new floor, effectively doubling it's size, with dormer windows. However, for your house I would, from the outside of the roof, use a permiable membrane stretched tight, counter batterns along the joists, the battered and tiles or slates.On the underside, fill between the joists with rock wool, then use full sheets of celotex (I used 50mm) across the underside of the joists. If properly taped across the joins, no vapour barrier should be needed. This will give you an excellent storage area with no need to add insulation below any loft flooring. It will also protect any pipework and boiler from frost.
Of course, when I wrote joist, I meant rafter!
