CHJ
Do you have a handy Tool or piece of Equipment that has a little niggle built in?
My current expletive generating tool is the simple Moisture Indicator from Axminster:
More than adequate in Indicated Moisture for my needs in assessing wood for turning.
The Niggle(s).
It has an easy use "Press On" -- "Press Off" Button on the case.
1. It has no indication that it is on other than shorting the prongs, that is unless the battery is low when it lights up like a Xmas tree.
2. How do you carry the ***!!*** thing around with you without flattening the battery.
Put it in a pocket or keep it in the car glove box so that you have it to hand when traveling and you can be sure that the battery will be flat next time you press the button. Even putting it on the workshop shelf can fall foul of something else resting against or on the button.
Taking the battery out whilst transporting it around or making a Bespoke Container for a "Pocket sized" hand held tool just does not produce contentment.
The Niggle(s).
