Angle grinder..which size discs?
lastminute
26 Apr 2009
West Yorkshire
Confused about the different sizs discs ie. 5" and 115mm.
Can both sizes be used in the same grinder?
Thanks for any advice.
Gerry
As sunnybob says. If you're buying metal cutting discs, I'm trying out a diamond disc for metal at the moment and it's been good so far but only had a little use.
You can uses a 115mm (4.5") on a 5" as it fits inside the guard.
But a 5" will not fit a 115mm, with out removing the guard.
That way leads to madness.
I uses 4.5 grinders as they are the most common size local to be.
