I've got sufficient wood from section of a UK cherry tree for all of the construction work for a Viennese clock case but I'm not so sure about the backboard. Fancy says some thin t&g boards if there is enough wood - logic says veneer on 6mm ply.
If I go the latter route I've two queries - will American cherry veneer match adequately as I suspect that is all I will be able to get, and secondly should I balance the ply with veneer on the back face and what sort?
Many thanks
OW
Many thanks
OW
