Racers
- Joined
- 22 Apr 2005
- Messages
- 9,172
- Reaction score
- 136
Hi,
I have lots of 4mm Allen keys so I decides to have a go at making small knives for carving marking out etc,
You need a MAPP torch to heat the keys up to red hot and something to bash them on, I use a 56Lb weight.
Get it nice and hot
Bash it into a rough shape
Let it cool slowly and file it into shape
Cut the end off (you might need to heat it up to anneal it) and then heat the blade to red hot
And plunge into water
It will now be hard, clean up with wet and dry etc.
Now take a small piece of nice wood, drill a 4mm hole in the middle
And shape the sides
Knock off the corners
Hold the blade in the vice and tap on the handle
Sharpen and test
And put it with the others
Sorry about the pics most of then where taken one handed.
Get it nice and hot
And shape the sides
Sharpen and test
