devonwoody
Got email this morning
MrDavidRoberts":3jsyns4v said:If you want headache/lost time = buy Aldi/Lidl tools..
If that's all the budget you have= look on ebay for good quality used tools instead.
Bodgers":nu8i44bv said:MrDavidRoberts":nu8i44bv said:If you want headache/lost time = buy Aldi/Lidl tools..
There are some outliers that are good - particularly from Lidl. This Aldi tablesaw probably isn't one of them.
The Lidl chisels are great. Some of the Lidl Parkside power tools are also fine. 20v SDS drill and Tracksaw are also good, so unwise to make sweeping statements...
whatknot":1d5dvh6p said:I have the Aldi table saw, it does what I expect of it
I can't afford hundreds of pounds for a table saw, so its either the Aldi version or none
Plus they have a three year warranty and delivered to my door for free
There are plenty of tools I would buy second hand, but a table saw isn't one of them, the reason most are put up for sale is they are worn out and knackered, heavily used by tradesman and as I quite like my fingers and wish to keep them I wouldn't trust a table saw on its last legs
There seems to be some snobbery regarding Aldi / Lidl tools which are very often just re-badged more well known makes, like Scheppach
All the tools I have had from either Aldi / Lidl do all I expect of them, drills drill, saws saw, the bits and accessories are lower quality and won't last as long as more expensive makes, but if you are only using them on and off they do a job of work
whatknot":d1ku5k5h said:I have the Aldi table saw, it does what I expect of it
I don't necessarily agree with that; I believe it depends on what you are using the tablesaw for.Bodgers":2z15eyc3 said:in the case of a tablesaw it lives and dies by its repeatability and accuracy
Just4Fun":3gri8cvl said:I don't necessarily agree with that; I believe it depends on what you are using the tablesaw for.Bodgers":3gri8cvl said:in the case of a tablesaw it lives and dies by its repeatability and accuracy
Being basically a hand-tools only woodworker who recently got access to a low-quality tablesaw, I use it for rough dimensioning of my timber. It isn't the most accurate or repeatable tool but using it to rip long lengths of timber to rough width before planing it is much easier than using a hand saw. Of course, if you want to do joinery with the tablesaw (and many people do) then you need something more accurate and repeatable, but that is not essential for every use.
As with any tool purchase I think you should identify your real needs then look for a tool to meet those needs.
Possibly, I really don't know. I have no knowledge of bandsaws.Bodgers":1597dl5e said:I take your point, but in this case a bandsaw might be a better and safer bet for rough dimensioning stuff surely?
Stevebod":2q7ev740 said:..I got the Aldi Band saw last year, and for the money it has been absolutely brilliant....that is its been loads better than the alternative, (ie no bandsaw)...would I buy one if I was a "professional / heavy user ? definitely not.....would I recommend one for a one off project / light DIY use...definitely yes!!
I would assume the table saw is of the same ilk, if you have a "light" need and you are prepared to accept its limitations with a 3 yr return warranty what have you got to loose?!
